leshich-k
STM32 CubeMX 4.23.0 bug (ADC1+DMA+TIM6_TRGO)
  • November 8, 2017
  • 548 views
Posted on November 08, 2017 at 12:33
Generated a project for STM32F746 (Firmware Package for Family STM32F7 v1.8.0) that uses ADC1 + DMA + TIM6 (TRGO) for Keil MDA-ARM 5. Tried to run it - no trigger is received by ADC, so no convertion data is transferred over DMA.
The bug is documented in 'STM32F74xxx STM32F75xxx Errata sheet', page 7 (2.2.1). Workaround is to turn on CLOCK for DAC.
Please fix the bug in code generating .
    Posted on November 08, 2017 at 15:51
    I raised this issue internally to the CubeMx team for further check and investigation.
    Best Regards
    Imen
    Jeanne Joly
    Posted on February 13, 2018 at 14:22
    Hi
    Kozyrev.Alexey
    It should be available in the next CubeMX release.
    I will keep you informed.
    BR. Jeanne
