Steps to have external SDRAM work properly!
I'm editing linker and startup files according to the example "FMC_SDRAM_DataMemory" but i con not access SDRAM. In example, it has only 2 regions as FLASH and RAM but we have 5 regions as FLASH, DTCMRAM, SRAM1, SRAM2 and MEMORY_B1. Also how can an initialized array of size 255kB get place to external SDRAM before FMC is enabled? FMC is enabled in main. Please anyone can explain the steps to use external SDRAM properly?
I'm using STM32F746DISCO board and on-board SDRAM. IDE is Atollic TrueStudio.
Thank you.
