stack pointer incorrect
We are trying to migrate from IAR Kickstart kit with IAR-STM32F207ZG-SK board to our own board.
On our PCB we have STM32F207ZC mounted.
The small test code is successfully downloaded with J-Link.
Downloaded C:\data\p-1026-lockkort-pwm10\arm\examples\ST\STM32F2xx\STM32F2xx_StdPeriph_Lib\Project\STM32F2xx_StdPeriph_Examples\TIM\TIM10_PWMOutput\STM322xG_EVAL\Exe\TIM10_PWMOutput.out to flash memory.
But we get this warning:
Warning: Stack pointer is setup to incorrect alignment. Stack addr = 0xFFFFFFFF
We have changed to the device we use in IAR pre-processor settings.
Probably there is still a file somewhere that describe device used as STM32F207ZG
and set stack pointer to a non-existing SRAM address.
The downloaded program do not run.
Any suggestions where to look for and change device settings?
/Richard
