Tu Nguyen Ngoc
ST7540 application software doesn't work???
Posted on December 27, 2017 at 10:13
STEVAL-IHP005V1 application software doesn't work???
Hi all,
I tried to install software for testing Power line module based on ST7540 and STM32.
I installed it on window 7 and window 10, both of them can't start properly. I have no idea what happened.
Someone help me pls.
    @Tu Nguyen Ngoc
    Hello sir,
    Facing same situation here,
    From my end i am at-least able to communicate with computer and module using provided GUI tool, but not able to transmit or receive data from one node to another through power lines.
    It would be glad if you can provide some more insights from your side.
    I hope it may help me.
    I have raised this concern over ST-Online support portal but waiting for satisfactory reply from their team since last 10-days.
    Heavily blocked here.
    December 9, 2024
    I didn't see your post before, but I have the same issue. Hope you got a solution.
