ARoss.10
ST microcontroller Carbon footprint
  • April 14, 2023
  • 5 replies
  • 1513 views
Hi, I would like to know if it is possible to have the carbon footprint of ST32 microcontrollers. I searched around the websites but I cannot find this type of information.
    ARoss.10
    ARoss.10Author
    Hi, thanks for the answer.
    Can the value indicates on the page be considered valid for all the ST32 microcontrollers or is it valid only for one specific model?
    Are there differences between microcontrollers with different packages?
    April 17, 2023
    Undoubtedly, and how they are moved by air/sea from the diffusion site to the assembly plant, etc, and perhaps the weather.
    waclawek.jan
    Please note that this is a primarily user-driven forum, with casual ST presence. If you need some concrete data, for whatever reason, you may want to contact ST directly, possibly through the web support form.
    Billy OWEN
    Hi @Community member​
    The forum moderator had marked your post as needing a little more investigation and direct support. An online support case has been created on your behalf, please stand by for just a moment and you will hear from us.
    Regards,
    Billy
