petre
ST-Link/V2 Dead, isn't detected by any PC ! :) Please help..
  • April 5, 2013
  • 6 replies
  • 1456 views
Posted on April 05, 2013 at 10:12
Hi everybody,
After receiving the board and installing the kit from Keil plus1 hour of struggling with set-up the board was ok :), ran some examples. Ok, excellent, reflashed the ST Link with the new firmware using the ST Link Utility (CRC passed) and started debugging a code of mine, again, no problems. The next day, I had an idea, started my laptop plugged the board and nothing :) I thought it's my mistake or the laptop had problems because it didn't detect the board....Restarted the laptop and the board also, again, nothing, the board wasn't detected by the OS. I tried the same procedure on 4 computers and none detected it....
So, the RED LED is blinking and the power led is on...
Any ideas ?
Thanks,
Mihai P
    crt2
    April 5, 2013
    Posted on April 05, 2013 at 10:22
    What OS was this tried on? What code was on board when you shut it down?
    petre
    petreAuthor
    Posted on April 05, 2013 at 10:25
    Fast response :) I was talking about the fact that Windows or any other PC can't recognize the board. When I say can't recognize I mean nothing appears in device manager also I don't get an error from Windows. Simply nothing happens the board isn't detected.....
    Regards,
    Mihai P
    crt2
    April 5, 2013
    Posted on April 05, 2013 at 12:16
    Windows or any other PC - also Windows I might assume? Might I assume Windows 7?
    There could be a power problem but I would not know where to search for logs (dmesg) in Windows for that matter...
    petre
    petreAuthor
    Posted on April 05, 2013 at 12:52
    The board was test on Win 7 and Win Xp. No results until now. . . .
    crt2
    April 5, 2013
    Posted on April 05, 2013 at 12:57
    quoting clive1 from another thread: ''If your code is causing a problem pulling BOOT0 High at start up will remove it from being an issue.''
    Have you tried this?
    petre
    petreAuthor
    Posted on April 07, 2013 at 13:36
     Thanks for the info, looks like the st link is fried. Don't know how I did it but this is my problem. Order 2 new boads from Farnell just for redunfancy.
    Have a nice day,
    Mihai P
