supad
August 17, 2018
ST-Link/V2 by IAR IDE in STSPIN32f0: "fatal error no MCU find"
  • August 17, 2018
  • 1 reply
  • 631 views
when we debug and compile in ST-Link/V2 by IAR IDE in STSPIN32f0 then this shows a problen that fatal error no MCU find. so what should be do for remove this error
    Hello @supad​ ,
    I recommend you to upgrade firmware version using STM32 ST-LINK Utility: go to ST-LINK>firmware update. Then, disconnect and connect your board.
    And check the jumper position.
    With Regards,
    Imen
