Daniel Fernandes
Aug 17, 2018 2:44 PM UTC
ST-Link Utility bug in V4.2.0
I Previously used V4.0.0 (At least I think so) but sometime ago upgraded to V4.2.0. Now every second time I read a .hex from disk it crashes (having programmed the chip between file openings). The .hex is for a stm32H7 (doesn´t know if it makes a difference). I´m using Windows 7 64 bits. How can I report this back to ST?
    Imen.DBest answer
    Jan 4, 2019 4:10 PM UTC
    Hello @Daniel Fernandes​ ,
    The reading and flashing of .Hex file with STM32H7 is fixed using ST-Link Utility v 4.3.0 .
    Thanks,
    Imen.
    Aug 17, 2018 3:32 PM UTC
    @STOne-32​ @Imen DAHMEN​ could someone create an incident report and get the offending .HEX files to the respective teams.
    Have you tried the Cube STM Programmer? The Utilities seems to have been deprecated in favour of the new tools.
    https://www.st.com/en/development-tools/stm32cubeprog.html
    Aug 17, 2018 4:21 PM UTC
    We will raise and check this issue internally.
    I recommend you, as Clive said, to use the new STM32CubeProgrammer software tool.
    With Regards,
    Imen
    Imen.DBest answer
    Thanks,
    Imen.
