j239955_stm1_stmicro
ST-LINK_CLI.exe don't accept the -OB argument
Posted on August 04, 2016 at 11:11
ST-LINK CLI.exe don't accept the -OB argument
when i execute this commade line:
''C:\Program Files (x86)\STMicroelectronics\STM32 ST-LINK Utility\ST-LINK Utility\ST-LINK_CLI.exe'' –OB RDP=0
the software return :
STM32 ST-LINK CLI v2.5.0
STM32 ST-LINK Command Line Interface
Argument error.Use -? for help.
    Nesrine M_O
    Posted on August 04, 2016 at 11:31
    Hi junique.julien,
    you have to connect first:
    C:\Program Files (x86)\STMicroelectronics\STM32 ST-LINK Utility\ST-LINK Utility\ST-LINK_CLI.exe'' -c swd –OB RDP=0
    -Syrine-
    Posted on August 04, 2016 at 11:48
    if I execute this commande line
    ''C:\Program Files (x86)\STMicroelectronics\STM32 ST-LINK Utility\ST-LINK Utility\ST-LINK_CLI.exe'' -c swd –OB RDP=0
    the software return
    ST-LINK SN : 53FF74064980555739101187
    ST-LINK Firmware version : V2J23S4
    Connected via SWD.
    SWD Frequency = 4000K.
    Target voltage = 3.2 V.
    Connection mode : Normal.
    Device ID:0x448
    Device flash Size : 128 Kbytes
    Device family :STM32F072xx/F078xx
    but don't update the option bytes
    Nesrine M_O
    Posted on August 04, 2016 at 12:02
    Hi junique.julien,
    What do you mean by “but don't update the option bytesâ€�: a fail message has been appeared?
    Try this command to display option bytes:
    ''C:\Program Files (x86)\STMicroelectronics\STM32 ST-LINK Utility\ST-LINK Utility\ST-LINK_CLI.exe'' -c swd –OB RDP=0 -rOB
    Also I recommend you to have a look to the STM32 ST-LINK utility command line interface (CLI) section in the UM0892 User manual
    -Syrine-
    Posted on August 04, 2016 at 12:14
    There aren't  fail messages et no change in display option bytes
    for exemple:
    ''C:\Program Files (x86)\STMicroelectronics\STM32 ST-LINK Utility\ST-LINK Utility\ST-LINK_CLI.exe'' -rOB
    Connected via SWD.
    Device ID:0x448
    Option bytes:
    RDP         : Level 0
    IWDG_SW     : 0
    nRST_STOP   : 0
    nRST_STDBY  : 0
    nBoot1      : 0
    VDDA        : 0
    Data0       : 0x00
    Data1       : 0x00
    nSRAM_Parity: 0
    WRP         : 0xFFFFFFFF
    and
    ''C:\Program Files (x86)\STMicroelectronics\STM32 ST-LINK Utility\ST-LINK Utility\ST-LINK_CLI.exe'' -c swd –OB RDP=1 IWDG_SW=1 nRST_STOP=1 nRST_STDBY=1 nBoot1=1 VDDA=1 nSRAM_Parity=1 WRP=0xFFFFFFE0 -rOB
    Connected via SWD.
    Device ID:0x448
    Option bytes:
    RDP         : Level 0
    IWDG_SW     : 0
    nRST_STOP   : 0
    nRST_STDBY  : 0
    nBoot1      : 0
    VDDA        : 0
    Data0       : 0x00
    Data1       : 0x00
    nSRAM_Parity: 0
    WRP         : 0xFFFFFFFF
    Nesrine M_O
    Posted on August 04, 2016 at 13:12
    Hi junique.julien,
    I did the test from my side and there is any issue.
    C:\Program Files (x86)\STMicroelectronics\STM32 ST-LINK Utility\ST-LINK Utility>
    ''ST-LINK_CLI.exe'' -c SWD -rOB -OB RDP=1 -rOB -OB RDP=0 -rOB -pause
    ST-LINK SN : 0670FF555355755087081741
    ST-LINK Firmware version : V2J25M13
    Connected via SWD.
    Device ID:0x448
    Option bytes:
    RDP         : Level 0
    IWDG_SW     : 1
    nRST_STOP   : 1
    nRST_STDBY  : 1
    nBoot1      : 1
    VDDA        : 1
    Data0       : 0xDD
    Data1       : 0xDD
    nSRAM_Parity: 1
    WRP         : 0xFFFFFFFF
    Updating option bytes...
    Option bytes updated successfully.
    Option bytes:
    RDP         : Level 1
    IWDG_SW     : 1
    nRST_STOP   : 1
    nRST_STDBY  : 1
    nBoot1      : 1
    VDDA        : 1
    Data0       : 0xDD
    Data1       : 0xDD
    nSRAM_Parity: 1
    WRP         : 0xFFFFFFFF
    Option bytes:
    RDP         : Level 0
    IWDG_SW     : 1
    nRST_STOP   : 1
    nRST_STDBY  : 1
    nBoot1      : 1
    VDDA        : 1
    Data0       : 0xDD
    Data1       : 0xDD
    nSRAM_Parity: 1
    WRP         : 0xFFFFFFFF
    Press ENTER to exit.
    -Syrine-
    Posted on August 04, 2016 at 13:58
    It Works !!!! :)
    this command line wokrs for me thank you
    ''C:\Program Files (x86)\STMicroelectronics\STM32 ST-LINK Utility\ST-LINK Utility\ST-LINK_CLI.exe'' -c SWD -rOB -OB RDP=1 IWDG_SW=1 nRST_STOP=1 nRST_STDBY=1 nBoot1=1 VDDA=1 nSRAM_Parity=1 WRP=0xFFFFFFE0 -rOB -pause
    Connected via SWD.
    Device ID:0x448
    Option bytes:
    RDP         : Level 0
    IWDG_SW     : 0
    nRST_STOP   : 0
    nRST_STDBY  : 0
    nBoot1      : 0
    VDDA        : 0
    Data0       : 0x00
    Data1       : 0x00
    nSRAM_Parity: 0
    WRP         : 0xFFFFFFFF
    Option bytes:
    RDP         : Level 1
    IWDG_SW     : 1
    nRST_STOP   : 1
    nRST_STDBY  : 1
    nBoot1      : 1
    VDDA        : 1
    Data0       : 0x00
    Data1       : 0x00
    nSRAM_Parity: 1
    WRP         : 0xFFFFFFE0
    Thank you :)
    Nesrine M_O
    Posted on August 04, 2016 at 14:37
    Hi junique.julien,
    It is good to hear that it was solved , thank you for your interest on our STM32 related solutions.
    -Syrine-
