SR6P6C6 HSM enable DCF write in wrong place
Hello, I mistakenly programmed the HSM enable record into the host core DCF area at address 0x29F81A10. Could this introduce any risk of incorrect configuration?
I found that I can overwrite the incorrect DCF record by programming all 0xFF. However, I am concerned that the programmed 0xFF may differ from the 0xFF of an unprogrammed blank device. Could you advise whether this operation is valid?
muchCAuthor
Sorry I posted the Stella chip thread in the STM32 section, and I cannot change the section now.
muchCAuthor
can someone help?
muchCAuthor
Could you please arrange technical support to help clarify this for me?
HSM is module for hardware security. For HSM enable record info, do you mean any information before send to HSM or after
muchCAuthor
A Security DCF record 0x0004000600000043 should be write at HSM UTEST(0x2437D000-0x2437DFFF) to enable HSM module. My customer mistakenly write the record at HOST UTEST(0x29F81000-0x29F83FFF) .I found that I can overwrite the incorrect DCF record by programming all 0xFF,will that work?
