GPapa.7
Mar 26, 2019 2:40 PM UTC
SQLite on STM32F7 series
I'm trying to implement a DataBase connection with STM32F779NIHx.
I included the sqlite sources but received an error because the ioctl.h file is not present within the STM32F7XX HAL Driver. Where can I retrieve it?
After Forever
Senior III
Mar 26, 2019 3:43 PM UTC
SQLite doesn't know about your underlying storage layer. You'll have to port SQLite's VFS (virtual file system) interface to your microcontroller.
https://sqlite.org/c3ref/vfs.html - about VFS
https://sqlite.org/custombuild.html - about custom builds, also about porting requirements
[Click Show More]
I have to say that I'm not sure if STM32F7 can cope with SQLite. I don't know the library's minimum RAM/Flash requirements, but judging from poor search results with "sqlite stm32" or "sqlite freertos" keywords I am not too optimistic.
GPapa.7
GPapa.7Author
Mar 26, 2019 4:14 PM UTC
Thanks for your answer.
Second your opinion, is it possible upload a database on the STM32 on board SD card and communicate with it?
MikeDB
Senior II
Mar 26, 2019 11:32 PM UTC
Definitely possible but might be slow. I suspect you'd be better off with an ARM A series device where all of the work will have been done before by someone.
