mahdi zamani
Jul 30, 2017 8:57 AM UTC
spl RCC config for external oscillator
Posted on July 30, 2017 at 10:57
hi
i have connected &sharposcillator to &sharpOSC_IN (PD0) i used this function for init &sharpRCC at &sharpSTM32F103c8t6
but is not work with &sharppll and &sharpexternal oscillator please help to me ...
void RCC_Configuration(void){
ErrorStatus HSEStartUpStatus;
RCC_DeInit(); /// RCC system reset(for debug purpose)
RCC_HSEConfig(RCC_HSE_Bypass); /// Enable HSE
HSEStartUpStatus = RCC_WaitForHSEStartUp(); /// Wait till HSE is ready
if(HSEStartUpStatus == SUCCESS)
RCC_HCLKConfig(RCC_SYSCLK_Div1); /// HCLK = SYSCLK
RCC_PCLK2Config(RCC_HCLK_Div1); /// PCLK2 = HCLK
RCC_PCLK1Config(RCC_HCLK_Div2); /// PCLK1 = HCLK/2
RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9); /// PLLCLK = 8MHz * 9 = 72 MHz
RCC_PLLCmd(ENABLE); /* Enable PLL */
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET); /// Wait till PLL is ready
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); /// Select PLL as system clock source
while(RCC_GetSYSCLKSource() != 0x08); /// Wait till PLL is used as system clock source
thanks
mahdi
oscillator
#uphill-skiing
Jul 30, 2017 1:53 PM UTC
Posted on July 30, 2017 at 15:53
If you have an XO that's on all the time, lose
Make sure you set the flash wait states before switching to the 72 MHz clock.
mahdi zamani
Aug 1, 2017 12:29 PM UTC
Posted on August 01, 2017 at 12:29
sorry
can give me example of this ?
Aug 1, 2017 8:12 PM UTC
Posted on August 01, 2017 at 20:12
Doesn't the SPL have a whole bunch of examples? Here's a quick cleanup of yours using the advice I provided..
 RCC_HSEConfig(RCC_HSE_Bypass); /// Enable HSE, already on and hot
 FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable); // Enable Prefetch Buffer
 FLASH_SetLatency(FLASH_Latency_2); // Flash 2 wait state
 RCC_PLLCmd(ENABLE); // Enable PLL
https://community.st.com/tags#/?tags=uphill%20skiing
