阿亮之家
Jun 1, 2023 6:30 AM UTC
SPI6 with BDMA fails to send data and receives
i used the spi6 with bdma to send data,but it don't work.so i hope get help, thanks.
Jun 1, 2023 2:04 PM UTC
Hello 阿亮之家
First of all, you may need to upgrade to the latest versions of CubeFW and CubeMX.
Second, what is your SPI interface?
阿亮之家
Jun 3, 2023 2:29 AM UTC
hi F.Belaid
i use the spi6. The spi tx uses the BDMA channel 0. The spi rx uses the BDMA channel 1. i use the stm32cubeide to make the project, and i use the HAL_SPI_Transelation_DMA to send data, but the data can't be send.
do you have the examples about the BDMA ? i don't find data about BDMA.
