SPI1 Clock speed
i am using a Nucleo - F411RE board and i want to create a sine wave with an external DAC (mcp4922). So i initialized a SPI connection to send my sine wave table to the external DAC. The frequency of the ouput sine wave should have 40 KHz. At the beginning i was producing a nice sine wave with a 50 values sine wave table, the freqency was exactly 400 Hz. So i reduced the table and the result was a edgy sine wave with a freq of 4,3 KHz. Better freq but wors signal. So i checked the bus which my SPI1 is attached to, for the STM32F411RE it is the APB2 bus. In my CubeMX program it shows a clock of 16 MHz at this bus. The init function of the systemclock config looks like this:
void SystemClock_Config(void)
/**Configure the main internal regulator output voltage
__HAL_RCC_PWR_CLK_ENABLE();
__HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
/**Initializes the CPU, AHB and APB busses clocks
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
RCC_OscInitStruct.HSIState = RCC_HSI_ON;
RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
Error_Handler();
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
Error_Handler();
}The clock divider is 1. So the freq will be 16 MHz. My SPI init function looks like this:
static void MX_SPI1_Init(void)
/* SPI1 parameter configuration*/
hspi1.Instance = SPI1;
hspi1.Init.Mode = SPI_MODE_MASTER;
hspi1.Init.Direction = SPI_DIRECTION_2LINES;
hspi1.Init.DataSize = SPI_DATASIZE_16BIT;
hspi1.Init.CLKPolarity = SPI_POLARITY_LOW;
hspi1.Init.CLKPhase = SPI_PHASE_1EDGE;
hspi1.Init.NSS = SPI_NSS_SOFT;
hspi1.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_2;
hspi1.Init.FirstBit = SPI_FIRSTBIT_MSB;
hspi1.Init.TIMode = SPI_TIMODE_DISABLE;
hspi1.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
hspi1.Init.CRCPolynomial = 10;
if (HAL_SPI_Init(&hspi1) != HAL_OK)
Error_Handler();
}Here you can see that my SPI_BAUDRATEPRESCALER is 2. So SPI1 clk frq is 8 MHz. If i want to transmit 1 value from my sine table to the DAC it will take me 16 * 125 nS = 2µS. The period Time of 40 KHz is 25µs. That means in perfect conditions i can only just use 25µs/2µs= 12.5 values for my sine table. And there is still the time missing for the chip select. Is it even possible to generate 40Khz?
