boris239955_st
spi1 and dac1 conflict
Posted on September 18, 2011 at 22:38
I have observed a conflict between SPI1 and DAC1 on stm32f103ZG micro.
When spi1 is initialized first and then DAC1 the spi1 clock shuts down.
It is time sensitive, but I manage to make repeatable on stm3210E-EVAL board.
Common scenario is:
nw_spi_init(SPI_1);
  nw_spi_send_32(SPI_1, 0xffffffff);
  for(i=0;i<0x1f;i++);
  nw_dac_config();//error is caused here spi1 clk shuts down by dac1 if dac is enabled
  for(i=0;i<0x2f;i++);
SPI1 configuration is:
GPIO_InitTypeDef
gpioInitStruct;
 SPI_InitTypeDef
spiInitStruct;
 RCC_APB2PeriphClockCmd
(RCC_APB2Periph_AFIO ,
ENABLE
((RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOG | RCC_APB2Periph_SPI1),
ENABLE
 gpioInitStruct.
GPIO_Speed
GPIO_Speed_50MHz
 gpioInitStruct.
GPIO_Mode
GPIO_Mode_Out_PP
 gpioInitStruct.
GPIO_Pin
= GPIO_Pin_8;
 GPIO_Init(GPIOG, &gpioInitStruct);
SPI1_OUTPUT_EXTENDER_SW_CS_HIGH();
 gpioInitStruct.
GPIO_Mode
GPIO_Mode_AF_PP
 gpioInitStruct.
GPIO_Pin
= GPIO_Pin_5;//clock
 GPIO_Init(GPIOA, &gpioInitStruct);
 gpioInitStruct.
GPIO_Pin
= GPIO_Pin_7;//mosi
 gpioInitStruct.
GPIO_Pin
= GPIO_Pin_6;//miso
 gpioInitStruct.
GPIO_Mode
GPIO_Mode_IN_FLOATING
 spiInitStruct.
SPI_Direction
= SPI_Direction_2Lines_FullDuplex;
 spiInitStruct.
SPI_Mode
= SPI_Mode_Master;
 spiInitStruct.
SPI_DataSize
= SPI_DataSize_16b;
 spiInitStruct.
SPI_CPOL
= SPI_CPOL_Low;
// idle low
 spiInitStruct.
SPI_CPHA
= SPI_CPHA_1Edge;
//data captured on leading rising edge
 spiInitStruct.
SPI_NSS
= SPI_NSS_Soft;
// software driven with external pin CS low active
 spiInitStruct.
SPI_FirstBit
= SPI_FirstBit_MSB;
 spiInitStruct.
SPI_CRCPolynomial
= 7;
//not used
 spiInitStruct.
SPI_BaudRatePrescaler
= SPI_BaudRatePrescaler_8;
 SPI_I2S_DeInit(SPI1);
 SPI_Init(SPI1, &spiInitStruct);
 SPI_Cmd(SPI1,
ENABLE
The dac1 configuration is:
static
void
nw_dac_config
void
GPIO_InitTypeDef
  GPIO_InitStructure;
DAC_InitTypeDef
   DAC_InitStructure;
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,
ENABLE
   GPIO_InitStructure.
GPIO_Pin
= GPIO_Pin_4;
   GPIO_InitStructure.
GPIO_Mode
GPIO_Mode_AIN
   GPIO_Init(GPIOA, &GPIO_InitStructure);
/* DAC channel1 Configuration */
    DAC_InitStructure.
DAC_Trigger
= DAC_Trigger_Software;
    DAC_InitStructure.
DAC_WaveGeneration
= DAC_WaveGeneration_None;
    DAC_InitStructure.
DAC_OutputBuffer
= DAC_OutputBuffer_Enable;
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_DAC,
ENABLE
    DAC_Init(DAC_Channel_1, &DAC_InitStructure);
/* Set DAC Channel1 DHR12L register */
    DAC_SetChannel1Data(DAC_Align_12b_R, 0x7FF);
static
void
nw_dac_start
u16
voltage)
//mV
#define
NW_ADC_VREF_mV   ((u16)3000)
#define
NW_ADC_COUNT_MAX   ((u16)4095)
u32
data = (voltage > NW_ADC_VREF_mV ?  NW_ADC_VREF_mV : voltage) * NW_ADC_COUNT_MAX;
//enable DAC channel
  DAC->
CR
|= (DAC_CR_EN1 << DAC_Channel_1);
  DAC_SetChannel1Data(DAC_Align_12b_R, (
u16
)(data / NW_ADC_VREF_mV));
/* Start DAC Channel1 conversion by software */
  DAC_SoftwareTriggerCmd(DAC_Channel_1,
ENABLE
Has anyone experienced similar problems?
