jerrywalker
Jul 21, 2019 1:28 PM UTC
SPI problem in STM32F10x
I have a problem with setting up SPI1 in Master mode using the following code. I set the SSM bit to enable software slave management, but when I try to enable the SPI by setting the SPE bit, the MSTR bit is cleared.
Thanks for help.
Jaroslav
RCC->APB2ENR |= RCC_APB2ENR_IOPAEN | RCC_APB2ENR_AFIOEN | RCC_APB2ENR_SPI1EN;
	GPIOA -> CRL &= 0x000FFFFF;
	GPIOA -> CRL |= 0xB4B00000;	/// PA7 - MOSI, PA6 - MISO, PA5 - SCK
	SPI1->CR1 &= ~SPI_CR1_BR;	// baud rate = fpCLK/2
	SPI1->CR1 &= ~SPI_CR1_CPOL;
	SPI1->CR1 |= SPI_CR1_CPHA;
	SPI1->CR1 &= ~SPI_CR1_DFF;
	SPI1->CR1 &= ~SPI_CR1_LSBFIRST;
	SPI1->CR1 |= SPI_CR1_SSM;	// software slave management
	SPI1->CR1 |= SPI_CR1_MSTR;
	SPI1->CR1 |= SPI_CR1_SPE;
waclawek.jan
Jul 21, 2019 11:12 PM UTC
Which STM32?
When you set SSM, the SS input is governed by state of SSI bit - if it's 0, it's the same as if you'd not set SSM and pulled the NSS pin low, i.e. it switches to slave mode.
PS. A stylistic one: I prefer to set peripheral registers all at once, in a single write, instead of a series of RMW operations.
jerrywalker
Jul 31, 2019 4:12 PM UTC
Thank you.
