SPI MOSI idle state quirk - sometimes high, sometimes low
I'm DMAing a buffer to the SPI transmitter, and require the idle state of the MOSI line to be low while the next buffer is waiting for its queue to be sent.
After some limited testing (STM32L433) I have found that the idle state of the line depends on the LSBit of the second to last word sent in the buffer. If that bit is low, the idle state is low, etc.
I'm assuming there is no way to ensure that the line stays low without sending two 0's at the end of the buffer (but if there is, please let me know)
