Dec 29, 2023 8:53 PM UTC
SPI + I2C Example Project
I am struggling to get SPI and I2C to work at the same time on my project I have tried multiple things (DMA, interrupts etc...) are there any example projects that already have this implemented? I am simply trying to read an I2C sensor value and show it on an SPI screen, as soon as I enable the SPI TFT the I2C returns zero values....
Pierre_Paris
Jan 2, 2024 9:57 AM UTC
Hello @Linkpad,
Thank you for your question !
Here some Remark :
  • What is your stm32F3 ?
  • Can you please share your code/configuration for SPI and I2C ?
  • Are you using HAL_I2C_IsDeviceReady() and HAL_I2C_Mem_Read() function ?
  • I2C returns zero values -> Is the function return an error or success code ?
  • Did you use the debug mode ? Have you scoped SDA and SCL ?
Best Regards,
Pierre
LinkpadAuthor
Jan 2, 2024 10:32 AM UTC
Hi Pierre,
Thanks for the advice what was happening in this case is the STM32F303K8 Discovery Board was pulling the I2C system low as soon as SPI was initiated, I swapped the project to an STM32F412G Discovery Board and the problem went away and is now working fine. I think some discovery boards have limitations on functionality (with jumper settings).
Patrick
Billy OWEN
Jan 2, 2024 4:46 PM UTC
Hi @Linkpad
The forum moderator had marked your post as needing a little more investigation and direct support. An online support case has been created on your behalf, please stand by for just a moment and you will hear from us.
Regards,
Billy
