Jonathan Kim
Apr 12, 2023 8:22 AM UTC
SPI communication on STM32H7
Working on interfacing Nucleo-H7A3 to COMX-CN-FB evaluation board which embedded netX made by Hischer using SPI interface.
Using SPL's SPI Transmit & Receive library, I implemented and proved the SPI data transmit & receive and confirmed SCK, MISO, MOSI, and SS signal on the Nucleo-H7A3 evaluation board.
And then, I transformed the source code for the Nucleo-H7A3 evaluation board but did not get the expected results on the oscilloscope. What did I miss out on configuring SPI, and what is this phenomenon induced from?
Please refer to the screenshot of the SPI oscilloscope waveform on the Nucleo-H7A3 evaluation board and on the Nucleo-F446 evaluation board in the attachment file.
S.Ma
Principal
Apr 13, 2023 2:00 AM UTC
The SPI IP generation/version is different between F4 and H7. HW Fifo being one difference in the data flow.
Jonathan Kim
Apr 13, 2023 8:41 AM UTC
Thank you for your reply.
What are there differences between F4 and H7 for SPI IP generation?
And where can I get some reference materials for SPI implementation of H7?
Pavel A.
Apr 13, 2023 2:01 PM UTC
AScha.3
Apr 13, 2023 3:59 PM UTC
another problem could be the cache...
just try: D-cache off.
