SPI communication - interval between bytes
Question about SPI communication interval
We are using HAL_SPI_TransmitReceive to achieve SPI communication, but there is an interval of some us after the SCLK outputs for 8 bits. Is it possible to change this interval time?
Andrew Neil
Andrew NeilBest answer
That's probably just the overhead in the HAL code while it handles completion of the previous byte, fetches the next byte, and starts transmission of that next byte.
What compiler optimisation level are you currently using? What happens if you increase it?
Have you tried using DMA?
Otherwise, optimise the code by hand.
Andrew Neil
Thank you for your response.
I see what you mean!
Then we can optimize the HAL code or use DMA for SPI communication!
