[SOLVED]storing struct into flash
Posted on August 31, 2015 at 11:04
Hello
I am trying to save my settings into flash. I use a struct that storing settings, then put a pointer begining of it and store all the bytes into flash along the size of that struct. But it seems struct is scattered in RAM. Is there an instruction that puts in Flash without scattered. I triedstruct __attribute__((packed, aligned(4))) network_settings_t{
unsigned char DHCP;
ipAddress_t ip;
ipAddress_t subnet_mask;
ipAddress_t gateway;
ipAddress_t dns;
char MAC_ADDRESS[6];
but it didn't work
I am using old drivers with GCC on STM32F107RTC
uint32_t address = FLASH_USER_START_ADDR;
uint32_t *ptr;
ptr = data;
FLASHStatus = FLASH_ErasePage(FLASH_USER_START_ADDR);
FLASH_WaitForLastOperation(100);
FLASH_ProgramWord(FLASH_USER_START_ADDR,*ptr);
ptr = &network_settings;
address += 4;
while(ptr <= (&network_settings + sizeof(network_settings))){
FLASH_ProgramWord(address,*ptr);
address += 4;
ptr += 4;
and to read it:
unsigned int *mem;
unsigned int *ptr;
printf(''Load Settings From Flash\n'');
printf(''Loading Settings...\r\n'');
mem = (unsigned int*)FLASH_USER_START_ADDR;
while(ptr <= (&network_settings+sizeof(network_settings))){
*ptr = *mem;
ptr += 4;
mem +=4;
Thank you...
