igal
Sep 9, 2013 3:04 PM UTC
Software interrupt doesn't work - please help
Posted on September 09, 2013 at 17:04
I try to set a software interrupt.
I set it as follows:
&sharpdefine HZ500_EXT_INT_LINE                                EXTI_Line1
&sharpdefine HZ500_EXT_INT_IRQ                                    EXTI1_IRQn
&sharpdefine HZ500_EXT_INT_PREEMPTION                    1
&sharpdefine HZ500_EXT_INT_SUB                                    2
void init_500hz_event_interrupt(void)
  EXTI_InitTypeDef   EXTI_InitStructure;
  NVIC_InitTypeDef   NVIC_InitStructure;
  /* Enable SYSCFG clock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE);
  /* Configure EXTI Line1 */
  EXTI_InitStructure.EXTI_Line = HZ500_EXT_INT_LINE;
  EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Event;
  EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising_Falling;
  EXTI_InitStructure.EXTI_LineCmd = ENABLE;
  EXTI_Init(&EXTI_InitStructure);
  /* Enable and set EXTI1 Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = HZ500_EXT_INT_IRQ;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = HZ500_EXT_INT_PREEMPTION;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = HZ500_EXT_INT_SUB;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
I have an ISR routine that is triggered by an external interrupt and it should trigger the software interrupt, I use the following command in order to trigger the software interrupt:
EXTI_GenerateSWInterrupt(HZ500_EXT_INT_LINE);
Unfortunately the software interrupt is not trigered. Am I missing something?
The ISR for the interrupt routine is defined as follows:
&sharpdefine HZ500_EXT_INT_HANDLER                                                    EXTI1_IRQHandler
void HZ500_EXT_INT_HANDLER(void)
    static uint8_t hz_100_creation;
    EXTI_ClearITPendingBit(HZ500_EXT_INT_LINE);
    TOGGLE_TP23;
    read_ppg_led_registers();
    hz_100_creation++;
    if(hz_100_creation >= HZ_100_COUNT)
        hz_100_creation = 0;
&sharpifdef RAW_DATA_MODE
        dls_dicmation();
&sharpelse
        dls_100hz_section();
&sharpendif /* RAW_DATA_MODE */
Thank you for your help
#exti #event #stm32-exti-software-interrupt" #software-interrupt"
Sep 9, 2013 8:26 PM UTC
Posted on September 09, 2013 at 22:26
EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
igal
igalAuthor
Sep 10, 2013 6:29 AM UTC
Posted on September 10, 2013 at 08:29
But since SYSCFG_EXTICR1 = 0; transitions on PA1 will cause interrupt too, I don't want the external port to cause interrupt
igal
igalAuthor
Sep 10, 2013 8:17 AM UTC
Posted on September 10, 2013 at 10:17
I found a solution
I cancelled the lines:
instead of using EXTI_GenerateSWInterrupt I use NVIC->STIR = HZ500_EXT_INT_IRQ;
Clive's solution works but it also causes external interrupt from the port and not only software interrupts, so it's not good for my purposes. I though setting the type to event will disable external interrupts but will enable software interrupts using EXTI_GenerateSWInterrupt. I was wrong.
If anyone has a better way of doing it or if my solution is not a healthy one I will be extremely happy to hear about it
Thank you
oliver23
Oct 16, 2013 11:32 AM UTC
Posted on October 16, 2013 at 13:32
Hi
I have had the same problem and found another solution:
    EXTI->RTSR = 0x0000;
    EXTI->FTSR = 0x0000;
This will disable rising and falling edge trigger detection.
There will be no trigger from external pin.
I recommend updating the library to have this option, doing the above:
EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Software_Only;
I am open to other suggestions.
