MSecr.1
Jan 13, 2022 7:45 AM UTC
Software doesn't work when switching to a other revision of board
I'm using a STM32F469 Discovery board, i was using a board with B-01 revision, my software works just fine, now i want to use the same board but with B-03 revision but for some reason the same software doesn't work on this board.
Note: B-01 rev flashes through J-Link
B-03 rev flashes through ST-Link
Mike_ST
Jan 13, 2022 9:38 AM UTC
You should give more information about what part of your software fails when you're debugging.
MSecr.1
MSecr.1Author
Jan 13, 2022 12:34 PM UTC
It's not very clear what causes the software to fail, it randomly goes to hardfault from different FreeRTOS tasks. I'd like to know if there is some evidence of differences between revisions, I struggle to find some information about this
Jan 14, 2022 4:31 AM UTC
Are you using SDRAM?
You're likely going to need to run the Hard Faults to ground, and identify any commonality​.
S.Ma
Principal
Jan 14, 2022 2:46 AM UTC
Check the chip errata sheet document, might give some additional clues.
