Soft Detach on USB
Posted on December 02, 2011 at 10:57
In my design, it is necessary to be able to change serial number by command on the USB... I can change the memory no issue (and save it to data EEPROM and retrieve it) no issue.
How do I then detach the device from the USB bus and re-attach it?Mike
