RobNeWin
skip flash erase before programming
  • May 10, 2023
  • 1165 views
hello,
Which command is valid to do this? I see --skipErase, I have also seen --ske, or ske as possible commands to use.
What is the syntax for this command? I dont see a reference in the manual...
Please help thanks in advance.
    Foued_KH
    Hello @RobNeWin​ ,
    The equivalent of 'Skip Flash Erase' option is 'ske' to be used with ST-LINK_CLI.exe.
    Foued
    RobNeWin
    RobNeWinAuthor
    @KHALSI_Foued​  great, what is the syntax to send this command?
    Do I do this before the download (-w)? or after? or a separate command?
    thanks!
