baranovus
Simulator warning '' __vector_table symbol not found'' in IAR
  • August 5, 2010
  • 1335 views
Posted on August 05, 2010 at 18:12
Simulator warning ' __vector_table symbol not found' in IAR
    nanayakkaraan
    Posted on May 17, 2011 at 14:01
    Hello Alexandar,
    At the moment I am also getting the same warning as you.
    ''Fri Oct 29 14:43:32 2010: Warning: __vector_table symbol not found. e_entry value: 0x0800010C does not match reset vector value: 0x48096001 Initial SP_main value:0x21084809 uncertain. ''
    And I cant load my program to STM32 as well.
    Have you found any solution?
    Or else does anybody have come up and solve up such situation?
    Thank you.
    May 17, 2011
    Sounds like your startup.s (startup_stm32f10x_md_vl.s or whatever) assembler file with the initial SP, PC and interrupt vectors is missing from your project.
