ggowd.1
Jul 17, 2024 11:44 UTC
Signal Generator in AD9850
Hi Team,
Can we interface AD9850 DDS Signal Generator Module with STM32F407G to generate sin wave and square wave, is there any procedure or links to interface between AD9850 with STM Microcontroller.
Best Regards
Gagan Gowda
mƎALLEm
mƎALLEmBest answer
Jul 17, 2024 12:01 UTC
Look at these links:
https://github.com/Derecho/stm32-ad9850/blob/master/ad9850/ad9850.c
https://github.com/DK7IH/STM32-F4-Demos/blob/main/_Oscillators/_AD9850/AD9850_FM_par.c
Google is your friend. Just put: "AD9850 STM32"
mƎALLEm
mƎALLEmBest answer
Jul 17, 2024 12:07 UTC
Yes, should be able to interface with GPIO driving the serial or parallel bus.
Suggest you spend some time with the data sheet, and apply basic interfacing methods.
https://www.analog.com/media/en/technical-documentation/data-sheets/ad9850.pdf
Don't limit yourself to STM32 specifically, the interfacing methods and software would be universal between MCUs
Andrew Neil
Jul 17, 2024 12:14 UTC
Indeed.
@ggowd.1 - How To Interface Anything to Anything Else:
http://www.8052mcu.com/forum/read/160143
You might also try looking for Arduino libraries ...
