tsutera
April 6, 2010
Shutting Down PWM Outputs At A Breakpoint
  • April 6, 2010
  • 1 reply
  • 419 views
Posted on April 06, 2010 at 17:32
    swhite2
    Posted on May 17, 2011 at 13:46
    If you're using the ST Standard Peripheral Library take a look at the DBGMCU_Config() function. That can be used to stop timers when the core is halted which may or may not be what you wan.
