Setup Custom Node for iota in B-L4S5I-IOT01A
Hello
I added a custom node and changed the default from the original code
(https://api.lb-0.testnet.chrysalis2.com/ ) ,but i noticed i get some error messages from the functions of the main menu .I would like to know if that has anything to do with the usertrust_thetangle.pem file , and if there is any specific configuration in the code for adding a custom node .
