Setting up SPI-bus
Posted on April 11, 2011 at 10:56
Hey, Im trying to set up an SPI-bus between the STM32VLDISCOVERY and an external flash memory. I want the STM32-processor to be master and the flash-memory to be slave.
What ive tried to far is simply to set up the GPIOs and also trying to send simple data but i get nothing. Im using an oscilloscope to read Pin7 on PortA on the STM32board. Obviously im doing something wrong but i dont really know what. Probably its some code missing? This is what i have so far: &sharpinclude ''stddef.h'' &sharpinclude ''stm32f10x.h'' &sharpinclude ''stm32f10x_gpio.h'' &sharpinclude <stm32f10x_spi.h> &sharpinclude ''string.h'' &sharpdefine SPI_COMMS SPI1 &sharpdefine PORT_SPI_COMMS GPIOA &sharpdefine PIN_SPI_COMMS_NCS GPIO_Pin_4 &sharpdefine PIN_SPI_COMMS_SCK GPIO_Pin_5 &sharpdefine PIN_SPI_COMMS_MISO GPIO_Pin_6 &sharpdefine PIN_SPI_COMMS_MOSI GPIO_Pin_7 void GPIO_Configuration(void); void SPI_Configuration(void); void RCC_Configuration(void); int main(void) { GPIO_Configuration(); SPI_Configuration(); RCC_Configuration(); for(;;){ SPI_I2S_SendData(SPI1,0xAAAA); } } void SPI_Configuration(void) { SPI_InitTypeDef SPI_InitStructure; /* SPI_MASTER configuration -------------------------------------------------*/ SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex; SPI_InitStructure.SPI_Mode = SPI_Mode_Master; SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b; SPI_InitStructure.SPI_CPOL = SPI_CPOL_High; SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge; SPI_InitStructure.SPI_NSS = SPI_NSS_Hard; SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4; SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; SPI_InitStructure.SPI_CRCPolynomial = 7; SPI_Init(SPI_COMMS, &SPI_InitStructure); /* Enable SPI_MASTER TXE interrupt */ SPI_I2S_ITConfig(SPI_COMMS, SPI_I2S_IT_TXE, ENABLE); /* Enable SPI_MASTER */ SPI_Cmd(SPI_COMMS, ENABLE); } void GPIO_Configuration(void) { GPIO_InitTypeDef GPIO_InitStructure; // Enable SPI1 Pins Software Remapping // //GPIO_PinRemapConfig(GPIO_Remap_SPI1, ENABLE); // Configure SPI_MASTER pins: SCK, MISO and MOSI // GPIO_InitStructure.GPIO_Pin = PIN_SPI_COMMS_SCK | PIN_SPI_COMMS_MISO | PIN_SPI_COMMS_MOSI; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init(PORT_SPI_COMMS, &GPIO_InitStructure); GPIO_Init(PORT_SPI_COMMS, &GPIO_InitStructure); } void RCC_Configuration(void) { // Enable GPIO clock // RCC_APB2PeriphClockCmd(PORT_SPI_COMMS, ENABLE); } What am i missing? Thanks in advance for your help!! //Fredrik #spi
