SDRAM Option Missing for STM32H7A3ZIT6Q in CubeIDE
I selected STM32H7A3ZIT6Q to use external SDRAM. However, in STM32CubeIDE under Connectivity → FMC, the SDRAM option is not available.
When I select STM32H7A3ZIT6 (non-Q), the SDRAM option appears.
Does the STM32H7A3ZIT6Q support SDRAM, or is this a CubeIDE limitation?
Thanks.
AScha.3
AScha.3Best answer
this is on H7A ds , table 1 , see which packages have sdram... or not.
H7A§ZITxQ  has not.
pic. attached...
AScha.3
AScha.3Best answer
H7A§ZITxQ  has not.
pic. attached...
