Senior
October 9, 2024
SDIO port with 2 SDCARD Chip Select
I have a STM32F411 and I am ready using the SDIO port,
I would like to connect 2 SDCARD to the SDIO port and be able to switch from one to another like using a CS Chip select GPIO.
Is it possible ? how would I do that ?
Vincent
STTwo-32
STTwo-32Best answer
Bonjour @vbesson
As you can see on the paragraph 3.26 of the DS10314, you can only use only one SD Card each time.
Best Regards.
STTwo-32
STTwo-32
STTwo-32Best answer
Bonjour @vbesson
Best Regards.
STTwo-32
