SD4.1 compatible EMI Filter
Hi All,
I was looking for an EMI Filter for SD card interface in STM32H753VI design. I am going to use a 4 bit mode micro-SD card. I came across these two parts for which I am not sure whether they are compatible with SD memory card specifications version 4.1 that is supported by STM32H753VI.
Need your help to confirm its compatibility for below parts:
1. EMIF06-MSD02N16 (mentioned as it can be used for SD card)
2. EMIF06-MSD04F3 (in datasheet, it is mentioned as it will support SD 3.0. Will it work for 4.1 also by any chance?)
Suggestions on other parts are also welcome.
Regards,
Karthic V
