tran
Save info from RAM before VDD shutdown
  • June 9, 2009
  • 537 views
Posted on June 09, 2009 at 07:34
    ccowdery9
    Posted on May 17, 2011 at 13:14
    You need a large enough capacitor to hold up VDD for long enough to backup your data, and a GPIO pin configured to generate an interrupt, which is connected to a circuit that detects power fail.
    Chris.
    tran
    tranAuthor
    Hello all,
    Im using an STM32F101R6T6 , and im trying to use the flash memory to save some infomation from the RAM just before the VDD is shuted down ( when we have electrical problem, no source, micro cut of power...).
    How can i detect the micro cut?
    Can i have time after detecting it, to save some variables from RAM to Flash memory?
    Thanks you all
