Chris21
The document at the link you supplied says:
Before opening the STM32CubeMX ‘ioc’ file, make sure that the X-CUBE-DPOWER pack has been installed.
• Download the pack at https://www.st.com/en/embedded-software/x-cube-dpower.html
• Open the help tab and install the pack.
Once the pack has been installed, it is possible to check, change, modify the default workspace, and generate the
code for the IAR, Keil® or STM32CubeIDE compiler toolchains using the tab GENERATE CODE in the main
interface.
sudongAuthor
I have installed the DPower pack, but where can I find the sample project file?
