z1060
May 22, 2015 9:33 AM UTC
SAI block settings
Posted on May 22, 2015 at 11:33
help me please
to set up
the SAI
correctly.
I need a
mode
I2S standart, 32-bit frame, 24-bit data.
I
configured
my code:
  hsai_BlockA1.Instance = SAI1_Block_A;
  hsai_BlockA1.Init.Protocol = SAI_FREE_PROTOCOL;
  hsai_BlockA1.Init.AudioMode = SAI_MODEMASTER_TX;
  hsai_BlockA1.Init.DataSize = SAI_DATASIZE_24;
  hsai_BlockA1.Init.FirstBit = SAI_FIRSTBIT_MSB;
  hsai_BlockA1.Init.ClockStrobing = SAI_CLOCKSTROBING_RISINGEDGE;
  hsai_BlockA1.Init.Synchro = SAI_ASYNCHRONOUS;
  hsai_BlockA1.Init.OutputDrive = SAI_OUTPUTDRIVE_ENABLED;
  hsai_BlockA1.Init.NoDivider = SAI_MASTERDIVIDER_ENABLED;
  hsai_BlockA1.Init.FIFOThreshold = SAI_FIFOTHRESHOLD_EMPTY;
  hsai_BlockA1.Init.ClockSource = SAI_CLKSOURCE_PLLI2S;
  hsai_BlockA1.Init.AudioFrequency = SAI_AUDIO_FREQUENCY_48K;
  hsai_BlockA1.FrameInit.FrameLength = 64;
  hsai_BlockA1.FrameInit.ActiveFrameLength = 32;
  hsai_BlockA1.FrameInit.FSDefinition = SAI_FS_CHANNEL_IDENTIFICATION;
  hsai_BlockA1.FrameInit.FSPolarity = SAI_FS_ACTIVE_LOW;
  hsai_BlockA1.FrameInit.FSOffset = SAI_FS_BEFOREFIRSTBIT;//SAI_FS_FIRSTBIT
  hsai_BlockA1.SlotInit.FirstBitOffset = 0;
  hsai_BlockA1.SlotInit.SlotSize = SAI_SLOTSIZE_32B;
  hsai_BlockA1.SlotInit.SlotNumber = 2;
  hsai_BlockA1.SlotInit.SlotActive = 0xFFFF0000;
  HAL_SAI_Init(&hsai_BlockA1);
However, these
are not perceived
correctly.
    michaeljulius9
    Oct 22, 2015 4:21 AM UTC
    Posted on October 22, 2015 at 06:21
    My question is most likely related to this.  Has anyone got a 24-bit or 32-bit I2S transmitter working using the SAI peripheral?
    Scenario
    I have setup my project on a STM32756G-Eval board and used STM32CubeMX 4.10.1 with STM32F7 firmware package version 1.1.0 to generate my HAL libraries.  I’m using DMA to loop through a buffer of “audio dataâ€� and pass this into SAI1 peripheral.  I selected a low audio frequency or 16kHz (also tried 192kHz) and my I2S_CKIN is 216MHz.  The source code auto generated is:
    /* SAI1 init function */
    void MX_SAI1_Init(void)
      hsai_BlockA1.Init.AudioFrequency = SAI_AUDIO_FREQUENCY_16K;
      hsai_BlockA1.Init.SynchroExt = SAI_SYNCEXT_DISABLE;
      hsai_BlockA1.Init.MonoStereoMode = SAI_STEREOMODE;
      hsai_BlockA1.Init.CompandingMode = SAI_NOCOMPANDING;
      hsai_BlockA1.Init.TriState = SAI_OUTPUT_NOTRELEASED;
      HAL_SAI_InitProtocol(&hsai_BlockA1, SAI_I2S_STANDARD, SAI_PROTOCOL_DATASIZE_16BIT, 2);
    And:
    void HAL_SAI_MspInit(SAI_HandleTypeDef* hsai)
      GPIO_InitTypeDef GPIO_InitStruct;
    /* SAI1 */
        if(hsai->Instance==SAI1_Block_A)
        /* Peripheral clock enable */
        if (SAI1_client == 0)
          __SAI1_CLK_ENABLE();
        /* Peripheral interrupt init*/
        HAL_NVIC_SetPriority(SAI1_IRQn, 0, 0);
        HAL_NVIC_EnableIRQ(SAI1_IRQn);
        SAI1_client ++;
        /**SAI1_A_Block_A GPIO Configuration
        PE4     ------> SAI1_FS_A
        PE2     ------> SAI1_MCLK_A
        PE5     ------> SAI1_SCK_A
        PE6     ------> SAI1_SD_A
        GPIO_InitStruct.Pin = GPIO_PIN_4|GPIO_PIN_2|GPIO_PIN_5|GPIO_PIN_6;
        GPIO_InitStruct.Speed = GPIO_SPEED_LOW;
        GPIO_InitStruct.Alternate = GPIO_AF6_SAI1;
        HAL_GPIO_Init(GPIOE, &GPIO_InitStruct);
        /* Peripheral DMA init*/
        hdma_sai1_a.Instance = DMA2_Stream1;
        hdma_sai1_a.Init.Channel = DMA_CHANNEL_0;
        hdma_sai1_a.Init.Direction = DMA_MEMORY_TO_PERIPH;
        hdma_sai1_a.Init.PeriphInc = DMA_PINC_DISABLE;
        hdma_sai1_a.Init.MemInc = DMA_MINC_ENABLE;
        hdma_sai1_a.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD;
        hdma_sai1_a.Init.MemDataAlignment = DMA_MDATAALIGN_HALFWORD;
        hdma_sai1_a.Init.Mode = DMA_CIRCULAR;
        hdma_sai1_a.Init.Priority = DMA_PRIORITY_LOW;
        hdma_sai1_a.Init.FIFOMode = DMA_FIFOMODE_DISABLE;
        hdma_sai1_a.Init.FIFOThreshold = DMA_FIFO_THRESHOLD_FULL;
        hdma_sai1_a.Init.MemBurst = DMA_MBURST_SINGLE;
        hdma_sai1_a.Init.PeriphBurst = DMA_PBURST_SINGLE;
        HAL_DMA_Init(&hdma_sai1_a);
        /* Several peripheral DMA handle pointers point to the same DMA handle.
         Be aware that there is only one stream to perform all the requested DMAs. */
        __HAL_LINKDMA(hsai,hdmarx,hdma_sai1_a);
        __HAL_LINKDMA(hsai,hdmatx,hdma_sai1_a);
    And my test app simply does:
    static constexpr int DATA_SIZE = 1024;
    uint16_t data[DATA_SIZE];
    HAL_SAI_Transmit_DMA(&hsai_BlockA1, (uint8_t*) &data[0], DATA_SIZE);
    while(1);
    Problem
    When I use SAI_PROTOCOL_DATASIZE_16BIT, everything seems to work fine when I check the lines on a scope; but using SAI_PROTOCOL_DATASIZE_24BIT or SAI_PROTOCOL_DATASIZE_32BIT I get nothing at all out any of the lines.  Although it shouldn't really matter, I did also change the DMA to write words instead of half-words when using 24 and 32-bit output.  I also that I tried using the blocking funcion HAL_SAI_Transmit() instead of the DMA version and it had the same problem (worked for 16 but not for 24 or 32-bit).  (NOTE: There are some bugs in the HAL_SAI_Transmit() that I guess I can post as issues somewhere (?))
    Help
    Am I doing something wrong?  Has anyone had success with this peripheral at these rates?  It seems that I'm either doing something wrong in my setup or there are bugs in the HAL library or silicon...
