jlchoobs
Running Your DISCOVERY Board off ONLY ONE SINGLE AA BATTERY !
  • April 22, 2012
  • 0 replies
  • 478 views
Posted on April 22, 2012 at 22:03
Here is a Simple Project Change ... Running Your Project / Discovery Board off ONLY ONE SINGLE AA BATTERY ! :
Did you know - that you may be able to run your Projects (like a Stm32 Board, Stm32F4disc, Stm32LDisc, etc) off of a SINGLE AA BATTERY ? - SO READ ON !
I got caught up with (and have been wanting to try) the idea that I could run a Project off less than 3Volts - if I used a Voltage Multiplier.
I thought, if I am using Low Power Chips - than why do I need a Power Adapter for My Projects ??
Maybe, if I use a Voltage Multiplier than I can avoid the Adapter and Cables...
Project here :
[[this link/image has been flagged as malicious by our security scan software and has been deleted]]
