yang hong
rtc time
  • September 27, 2019
  • 3 replies
  • 1029 views
I am using NUCLEO-F429ZI. I add one battery on my board and work on RTC. RTC is working, however, all time(null), clock() and so on don't work properly as soon as I remove semi hosting. After I dig the information, I know time(NULL), clock() is working on semi hosting. Actual, I would like to have UTC time, local time, and RTC second for my application. Does anybody have some way to fix this issue? I know I can rewrite codes to get it, but if library is available, why we don't use it?
Thank you in advance.
KnarfB
After you have removed semihosting, you may provide your custom implementation in syscalls.c.
I.e. clock() finally calls int _times(struct tms *buf), and time() finally calls int _gettimeofday().
See https://github.com/32bitmicro/newlib-nano-2/tree/master/newlib/libc/time about the library code.
hth
KnarfB
yang hong
yang hongAuthor
Hello, KnarfB:
Thank you for your information. I check my library list. it looks like sw4stm32 includes newlib-nano folder. I add battery in my NUCLEO-STM32F429ZI, so I am interested in using the rtc time to be my clock. When I call _times(struct tms *buf), it seems it works because I can get time, but it seems the second value is the second since controller start up. Do you have any idea to implement rtc to clock() or _time() ?
Regards,
Yang
KnarfB
clock() calls _times(). So you implement _times as you need (for example RTC) and clock() should work.
Same for time(): implement _gettimeofday() as you need (RTC).
check with newlib https://sourceware.org/newlib/ under Docs Timefns
hth
KnarfB
