Prisma
May 27, 2021 9:02 AM UTC
RTC reset with VBATT
I have an STM32G0 with VBATT input for the RTC.
When I restart the circuit, the time is reset.
At the power On I write this instruction :
 HAL_RTCEx_BKUPRead(&hrtc, RTC_BKP_DR1);
Before of the Power Off :
HAL_RTCEx_BKUPWrite(&hrtc, RTC_BKP_DR1, 0x32F2);
Thanks for your Help.
Pascal
Prisma
PrismaBest answer
May 27, 2021 12:30 PM UTC
Hi Jan,
thank you. Solved the problem.
It was a mistake during the RTC init() setup.
Thank you for your help !!
Pascal
waclawek.jan
May 27, 2021 9:23 AM UTC
Is battery connected to the VBAT pin? What is its voltage, measured directly on that pin?
How does writing to backup register relate to time of RTC?
Is that backup register content retained during powerdown?
Prisma
PrismaAuthor
May 27, 2021 9:47 AM UTC
Hi Jan,
thanks for your help.
On the Pin = 2.7 V
I don't know how to write the current time on the register.
how can i check?
Thanks, Pascal
waclawek.jan
May 27, 2021 10:35 AM UTC
Why do you need to write it? And what is 0x32F2?
And what does that function return?
Prisma
PrismaAuthor
May 27, 2021 11:40 AM UTC
Hi Jan,
Time=HAL_RTCEx_BKUPRead(&hrtc, RTC_BKP_DR1);
Return Time= 11001011110010
What is the correct instructions for read the time and date after the Power On of the circuit ?
Thanks for your help.
Pascal
waclawek.jan
May 27, 2021 12:01 PM UTC
It does not differ from reading the time and date in any other instance... Normally, just read RTC->TR and RTC->DR (in this order, if BYPSHAD is 0).
I don't use Cube.
Prisma
PrismaAuthorBest answer
Hi Jan,
Pascal
