RTC on Timer Interrupts
I am using TIMER 14 for counting test durations in my projects however I am lagging off aroumd 5 mins per week.How can i implement the same with RTC counter?
Senior III
June 21, 2024
The accuracy depends on the crystal. If you really need very accurate timing, adjust the timer reload value or use external rtc such as ds3231 which can generate 1 sec pulse use it to.generate interrupt and do the counting.
