RTC internal timer or TIM 1 and TIM2 application from HAL library
Posted on October 06, 2016 at 08:26
Dear Sir,
While configuring STM32cubemx, my design does not contain any TIM1 or else.Now I am confused how should I configure Timer application for GPIO or other things.According to this vedio,https://www.youtube.com/watch?v=_wE7tbilca4&list=PLDin7xWrqlc-gJUiyHNHpfm9wjbsPBz5y&index=5timer can be applicable for input capture.You suggest me to apply systick in this case.What should I do now ?Look at this code kindly,void SysTick_Handler(void){ static uint32_t time = 0; time++; if ((time > 0) && (time <= 5)){ write_digit(1); write_led_7_segment(led_number[0]); } if ((time > 5) && (time <= 10)){ write_digit(2); write_led_7_segment(led_number[1]); } if ((time > 10) && (time <= 15)){ write_digit(3); write_led_7_segment(led_number[2]); } if ((time > 15) && (time <= 20)){ write_digit(4); write_led_7_segment(led_number[3]); if (time == 20){ time = 0; } }}
