KIbra.3
RTC drift
I am currently working on an RTOS application that includes RTC, and have observed that there is a clock drift of approx. 25 to 32 seconds after a 24-hour measurement cycle. Additionally, the drift seems to be not linear.
I've measured the RTC frequency and it was around 32.78KHz.
I would appreciate if anyone could provide any suggestions on how to improve the RTC performance.
waclawek.jan
waclawek.janBest answer
Which STM32?
What hardware?
What is the RTC clock source?
Does the "drift" increase with number of resets?
waclawek.jan
Which STM32?
What hardware?
KIbra.3
KIbra.3Author
I am using Discovery kit with STM32L4R9AI MCU and the RTC clock source is LSE 32.768KHZ.
I have to investigate whether the drift increases with reset, but the drift also appears without reset.
waclawek.jan
This is way too much error for LSE, and I don't assume the Disco would have problematic crystal/PCB layout.
Read out and check/post content of RCC_BDCR register, and possibly content of RTC registers too.
KIbra.3
KIbra.3Author
I noticed a significant increase in the drift when resetting the board many times. Do you think it would be advisable for me to check the RCC_BDCR?
waclawek.jan
What is "significant"? Is it in average about half a second per reset? If yes, resort to the link I've posted above.
KIbra.3
KIbra.3Author
The issue has been resolved in HAL_RTC_Init() looses time · Issue #24 · STMicroelectronics/STM32CubeH7 · GitHub as the number of times I reset the MCU had an impact on the drift.
Thanks for indicating the main cause of the problem.
