robinsm
Ride 7 RKit and ST library temple problem
Posted on August 31, 2009 at 07:43
    robinsm
    robinsmAuthor
    Posted on May 17, 2011 at 13:21
    The original post was too long to process during our migration. Please click on the provided URL to read the original post. https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I6Yd&d=%2Fa%2F0X0000000bqg%2FIvcbisPZkRrT37G3pd84KOUSkeP9vn4WzQPBj2hBH0s&asPdf=false
    robinsm
    robinsmAuthor
    I have newer versions.
    16-32micros
    Hi robinsm,
    Could you check that you have the right and latest version of Ride7, Here is my version and it working fine.
    Hoe this helps you.
    Cheers,
    STOne-32.
    [ This message was edited by: STOne-32 on 26-08-2009 22:01 ]
    [ This message was edited by: STOne-32 on 26-08-2009 22:02 ]
    robinsm
    robinsmAuthor
    I did a fresh install of everything, and still no luck.
    robinsm
    robinsmAuthor
    The template that comes with RIDE7 works fine (compiles okay), but the one in the new library (3.1.0) does not.
    16-32micros
    Hi robinsm,
    It seems a Ride7 tool-chain limitation in the latest version and for sure would be fixed in a new version from Raisonance, You can post you message here :
    http://raisonance-forum.xsalto.com/index.php
    Cheers,
    STOne-32.
    robinsm
    robinsmAuthor
    I will use the default template until the issues with the new library are resolved.
