ccowdery9
Retarget printf() on GCC / IDEaliST?
  • October 16, 2009
  • 12 replies
  • 3000 views
Posted on October 16, 2009 at 08:52
    slawcus
    Posted on May 17, 2011 at 12:55
    Try adding -msoft-float
    pramod
    May 17, 2011
    Thanks to Jeff, (
    http://sourceware.org/ml/newlib/2009/msg00073.html
    I found that I am using wrong library version. I changed it to another
    version found under sub-directory thumb/thumb2 and then it works fine!
    I did not have to ''build'' any new library. It already had many different
    versions, built using different options. Only I was using wrong version.
    Thank you all for your help.
    Regards,
    Pramod
