Restrictive ldscript files in Stm32Cube F1
Posted on July 06, 2015 at 19:13
I'm trying to decide if I want to use the STM32CUBE HAL code. Because I'm on linux, the cubemx thing doesn't run well, so I used the windows version and generated some code to use with openstm32 ( which also doesn't run well with linux ). I ignored all the openstm32 stuff and just created a new C project in standard eclipse. I setup all the include paths and symbols by hand.
I was feeling happy that I got it going without too much trouble and then I noticed this header in the linker script:/*
********************************************************************************* File : LinkerScript.ld**** Abstract : Linker script for STM32F103C8Tx Device with** 64KByte FLASH, 20KByte RAM**** Set heap size, stack size and stack location according** to application requirements.**** Set memory bank area and size if external memory is used.**** Target : STMicroelectronics STM32****** Distribution: The file is distributed as is, without any warranty** of any kind.**** (c)Copyright Ac6.** You may use this file as-is or modify it according to the needs of your** project. Distribution of this file (unmodified or modified) is not** permitted. Ac6 permit registered System Workbench for MCU users the** rights to distribute the assembled, compiled & linked contents of this** file as part of an application binary file, provided that it is built** using the System Workbench for MCU toolchain.*******************************************************************************Questions I have:1.) Is this intentional or just an overly cautious template in the cubemx code generator?2.) Are their other legal landmines lurking in the generated code that I should be aware of if my intent is to use this with open source code projects?-rick
