mj_it
Reset on the JTAG
  • November 21, 2007
  • 4 replies
  • 1070 views
Posted on November 21, 2007 at 05:18
Reset on the JTAG
    jgoril
    Posted on May 17, 2011 at 12:18
    See Cortex 3M Core Technical Manual, chapter 6.2 - Resets. NRST is equivalent of SYSRESETn, I think... This pin resets the entire processor system excluding of debug logic in NVIC, FPB, DWT, ITM, AHB-AP. There is none mention of SWJ-DP, but I think it is excluded too.
    mj_it
    mj_itAuthor
    I have one question about the Reset on the JTAG. Do you know what is it being reset with that feature NRST? Yes... I know what it means (to reset something) but in this particular case, I am not so sure about what it is done.
    Thank you,
    Marta
    mj_it
    mj_itAuthor
    I think that I understand right.
    So, thank you for your help!! Both messages have helped me.
    Marta
    joseph239955
    May 17, 2011
    I think the name of the signal asked by Marta should be ''nTRST'' (Test reset), not ''nRST''. This signal only reset the JTAG interface logic. It does not reset the processor core or debug components.
