vitthal muddapur
Reset MCU?
  • June 3, 2018
  • 6 replies
  • 1061 views
Posted on June 03, 2018 at 13:12
i am beginner in stm i am working on stm32l071, have configured rtc,spi,uart all peripherals working good,but
some time MCU resetting how to find what is reason for resetting  the mcu.
    June 3, 2018
    Posted on June 03, 2018 at 13:21
    Monitor the NRST pin vs the supply voltage, the system has a power-on-reset monitoring the supply for brown-out conditions.
    Check also PWR_CSR for Wakeup/Standby reset indication
    http://www.st.com/content/ccc/resource/technical/document/reference_manual/21/bd/0f/bd/1c/88/40/f0/DM00108282.pdf/files/DM00108282.pdf/jcr:content/translations/en.DM00108282.pdf
    Consider watchdog sources, and external drivers of the NRST pin
    john doe
    Senior III
    June 3, 2018
    Posted on June 03, 2018 at 13:26
    Read whats in RCC_CSR.  Here is a link to the reference manual.  Section 7.1 - Reset
    http://www.st.com/resource/en/reference_manual/dm00108282.pdf
    vitthal muddapur
    Posted on June 06, 2018 at 11:15
    any possibility to reset the device our firmware for uart ,spi(eeprom),LPTIMER
    i have flashed same firmware to 5 devices within this reset the 3 devices remaining two devices working good
    Vitaliy Chernobay
    Senior
    June 6, 2018
    Posted on June 06, 2018 at 11:23
    VCC is bad. Add shunt capacitor 0.1u
    vitthal muddapur
    Posted on June 07, 2018 at 08:10
    When i set like this GPIOA->ODR=1<<15 then MCU is resetting
    what is the Reason
    AvaTar
    Senior III
    June 7, 2018
    Posted on June 07, 2018 at 08:28
    How should we know, such code works fine on all the boards I have.
    What is connected to this pin ?
    Is your power supply too weak, or the supply circuitry inadequate ?
    Do you have a watchdog peripheral enabled ? (had already been asked, but not answered)
