Manoj Hiwarkar
Aug 17, 2018 11:13 AM UTC
Regarding Boot loader
Sir I want know that whether the boot loader code is already present in the STM32 MCUs by default ? or we have to download it.
Regards,
Manoj Hiwarkar
    Aug 17, 2018 3:35 PM UTC
    It is in OTP/ROM at delivery
    RN_it
    Aug 18, 2018 5:58 AM UTC
    Hello Manoj,
    Bootloader is in the system memory of MCU. by default MCU doesnot execute it. you have to configure the boot pins given.
    check here : https://www.st.com/content/ccc/resource/technical/document/application_note/b9/9b/16/3a/12/1e/40/0c/CD00167594.pdf/files/CD00167594.pdf/jcr:content/translations/en.CD00167594.pdf
    Manoj Hiwarkar
    Aug 20, 2018 12:09 PM UTC
    thank you sir. Sir one more query i have can you please tell me howto send one string "HELLO". using  HAL_CAN_Transmit function i have searched a lot but couldn't get a satisfied answer.
    Aug 20, 2018 12:32 PM UTC
    That's not really how CAN functions. You have an 8-byte data payload, you'd need to place your ASCII data within that.
    Manoj Hiwarkar
    Aug 20, 2018 1:18 PM UTC
    sir can i get one example program of the same ? it will be a great help.
    Aug 20, 2018 1:30 PM UTC
    Look at the examples provided in the HAL/Cube trees for the unspecified STM32 part you are using.
           /* Set the data to be transmitted */
           TxData[0] = 'H';
           TxData[1] = 'E';
           TxData[2] = 'L';
           TxData[3] = 'L';
           TxData[4] = 'O';
    TxHeader.DLC = 5; // Length
           /* Start the Transmission process */
           if (HAL_CAN_AddTxMessage(&CanHandle, &TxHeader, TxData, &TxMailbox) != HAL_OK)
             /* Transmission request Error */
             Error_Handler();
