reconfiguring PA15 to Output with Outputlevel 0 gives 'undefined instruction' Hard Fault
can someone validate the workaround with a board that shows the problem?
seems to be the same source as (but question is closed without any answer or workaround):
workaround: reconfigure with Outputlevel 1 and set Outputlevel to 0 after reconfiguration!
