Apr 3, 2025 6:00 AM UTC
Recommendation for STM32F4 MCU with Multiple UARTs, Quad SPI, and 100-120 MHz Frequency
Hello ST Community,
I am looking for an STM32F4 series microcontroller that meets the following requirements:
:small_blue_diamond: Microcontroller Requirements:
:white_heavy_check_mark: More than 2 UART ports
:white_heavy_check_mark: Quad SPI support
:white_heavy_check_mark: Operating frequency: 100-120 MHz
:white_heavy_check_mark: Preferred package: TQFP/LQFP, but open to other suggestions
Since this MCU will be used in an embedded system, power efficiency and peripheral availability are key considerations.
Andrew Neil
Andrew NeilBest answer
Apr 3, 2025 8:47 AM UTC
https://www.st.com/en/development-tools/st-mcu-finder-pc.html
https://www.st.com/en/development-tools/stm32-finder.html
https://www.st.com/content/st_com/en/stm32-mcu-developer-zone/mcu-portfolio.html
Distributors often have good parametric search tools ...
Peter BENSCH
Apr 3, 2025 7:06 AM UTC
Have you ever filtered your selection on the websites of the STM32F4?
/Peter
Mike_ST
Apr 3, 2025 8:42 AM UTC
For power efficiency as you mentionned, you might want to look at a newer STM32 range as the F4 family is a bit old.
For example STM32U5 or STM32L4+.
Andrew Neil
